how do i remove a rear case fan
Gongo
that is held by what looks like black plastic rivits? do i take a dremel and jsut chop the back and hope i can pull the fan out? and if that's the case, do i instal the fan with more rivits or screws?
take a picture of what u mean.... cus that makes no sence.
ill take a stab at it and say that you should just cut the heads off with a side cutter. that usually works...
pull the pins out with your nails, or get something flat to pop them out.
If this is a lian li or a case using a similar method then you just push the pin in the center out.
The rivets he's talking about are from Lian Li, right?
yeah it's a lian li case.. thanks it looks like they're plastic pushpins to secure the fan.. sry my first lian li case
