I have a Panasonic CT34WX15 TV ... it's a widescreen high-def tube. Unfortunatly, it doesn't come equipped with an ATSC tuner, so I can't just pick up a high-def antenna and pick up the OTA channels.
I've heard of external tuner boxes, but have no idea what they are called, or how to ask for them, or where to look for them, or who carries them, etc.
I'm assuming they are going to be fairly expensive, and probably not-so-friendly/easy to use...
so I also have another option.
I bought a 3 year service plan with my TV, so I might wait it out and see if it survives the 3 years ... and well, if it doesn't survive 3 years... the vender doesn't carry the tv anymore... so it can't be replaced with the same model... so I'll be able to pick out a new tv worth the same I paid for a 3 year old tube.. which would probably put me in a plasma and then just get a high def antenna then...
Thanks for the info !
