i like to use motherboard monitor....but what you could do is mentally remember the temp press the reset button on comp and check pc health quick... whatevers within a deg or two of that is w/e it was
i don't think mobo monitor gives the case temp readout tho. as i said, i already know which temps are my hdd/cpu/and mobo on speedfan. it's just that theres is another rogue temperature which i'm not sure if is my case temp.
does my mobo give me the case temp? or do i have to get a case with a built in thermometer?
