i found this speaker in my basement i m not sure what exactly happened to it or if its bad or anything
its just this speaker that says , on a sticker on the back,
PIONEER
S-P500D
MAXIMUM POWER 45W
IMPEDANCE (i m not sure what the number is, its scratched out but i think its 8 and this sign that looks like the ohm symbol)
PIONEER ELECTRONIC CORP
Serial No. K41
SAN 1403-A
and on another sticker,
MADE IN TAIWAN
i hope the info above gave you guys some sorta idea what kinda speaker it is but the weird thing is, that its not some small puny speaker, its like 6-8 inches tall, about 4 inches wide, and maybe 6 inches deep..... this does not seem powered by its normal audio input current so by common sense, it should have a power cable coming out of it right? nope, it doesnt all it has is two thin black and red wires coming out of it that goes to the audio input theres no other external power sources that cables that goes to a outlet or anything
now, my question, how is this thing powered? can a headfone jack provide enough audio electricity to power this kinda size picture? i know that there isnt a missing power cable or anything because if there was, then there must be a hole on the wooden speaker but there isnt
by the way, i have no idea what kinda interface or connector this uses because when i found it, the red and black wires were snipped and its only copper wiring showing outta the insulation
if i get a headfone and snipped of the plug, and wire it together myself and say, hook it up to a computer or a cd player, would that play?
i can provide pictures if its necessary but it may not be clear
PIONEER
S-P500D
MAXIMUM POWER 45W
Serial No. K41
SAN 1403-A
MADE IN TAIWAN
