How do I orient my MAZE4?
Dijonase
The install instructions for the MAZE4 are just those for the MAZE3, and they say that the inlet is nearest the center of the block and the outlet is nearest the edge of the block. Is it just me or is there no specific inlet or outlet on the MAZE4?
Also, where can I find 99% isopropyl alcohol? My local drug store has 91%, but I figure better safe than sorry, you know? ;)
The Maze4 block has no specific inlet or outlet, so don't worry about it. The Maze3 does, so thats just a mistake on dangerden's part.
91% versus 99% isopropyl alcohol makes no difference. If you can't find 99, then 91 will work just fine. There really isn't any advantage or disadvantage either way.
-OMP
-OMP
Check and check. I figured as much both on the orientation and the alcohol, but I just wanted to be sure. Thanks!
