I've got a 1U server that has Citrix XenServer 5.6 installed on it. It has 2 physical ethernet interfaces, both connected to the same network switch, one interface has a public IP address on it and the 2nd interface has a private rfc1918 address on it (this can be changed if necessary). I use the private1918 interface to do administrative tasks, transfer data amongst the servers and guest VMs, etc. I'm given a /29 IP address allocation by a friend to use for my servers (using his FTTP internet connection). I want to set up a few guest VMs, but really most of them do not need to be using public IP addresses.
Is there a way to NAT the public interface on XenServer so that guest VMs can use rfc1918 addresses & get online, instead of using the few IP addresses I am given? Also how would I enable portforwards so that I can get applications to work like asterisk, SMTP, etc?
My google foo doesn't seem to be helping me find the answer.
Listing of interfaces on the Xenserver:
Code:
eth0 Link encap:Ethernet HWaddr 00:30:48:92:AD:4E
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
eth1 Link encap:Ethernet HWaddr 00:30:48:92:AD:4F
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
vif1.0 Link encap:Ethernet HWaddr FE:FF:FF:FF:FF:FF
UP BROADCAST RUNNING NOARP MTU:1500 Metric:1
vif1.1 Link encap:Ethernet HWaddr FE:FF:FF:FF:FF:FF
xenbr0 Link encap:Ethernet HWaddr 00:30:48:92:AD:4E
inet addr:69.49.xxx.xxx Bcast:69.49.xxx.xxx Mask:255.255.255.248
xenbr1 Link encap:Ethernet HWaddr 00:30:48:92:AD:4F
inet addr:10.0.0.5 Bcast:10.0.0.255 Mask:255.255.255.0
