is it a made by ati card?
or a powered by ati card? (Powercolor, Saphire and so on)
on a made by ATI card you can tell right away, look at the pins holding the fan down if theyre gold its a 350 if theyre black its a 360
although im sure someone will tell you to also check the memory modules every card i have tried with black pins (5-6 of them now) worked like a charm. In fact thats the card im using in my main machine till i can afford a GF6800, no problems with doom 3 either on mine, but im using a VGA silencer 3 which i definitly recomened if your going to flash your card
