how do i install my hardrive and other stuff.
92Camaro
thism gith be really stupid but i got to thinking. i got an OEM hard drive and floppy and stuff. my question is this. how do i mount it in my case? i mean, are their any pics of exactly what holes are used to attach the harddrive to the case? i dont wanna run a bolt into the harddrive and have it like thread righ into the disk itself (eeek!) .
same for the floppy and for the cd burner.
I assume that you're going to be using the holes in the side of the Hard Drives / CD-Roms / Floppy Drive. The only thing you need to make sure is that you're not using a screw that is very long. The ones you need are fine threaded screws and are typically a phillips head.
Generally for all drives, the mounting screws will be no longer than 1/2 inch in length. (Usually are right around 3/8 inch length, maybe a hair shorter)
I have seen some drives that require the same length of screw, but only coarse threads instead.
edit: Mounting the drives usually doesn't require a lot of thought, but it does require a little bit of common sense. Usually if it doesn't fit right in smoothly, either something is blocking its entry, or its not supposed to go in the way you're trying. Once you get the drive slid into its resting postion, you'll see where the screw holes on the case and the drives line up.
Good luck.
lol.
the case came with a bunch of little screws but like i said, im new at this i knew they screwed n but i didnt know if their were a bucnha different holes or just mounting holes on the side odf the drive.
thanks
ok i forgot to ask this earleir about my hdd. like.. one side of it is "open" and one side has like.. a sticker with info on ti and stuff. which way is it orientated in the case? i HOPE with theo pen side down so dust doesnt settleo ni t. am i correct?
