djnes said:I don't think I've ever wanted to install something out of the C drive, as it's bad computer practices, but if the installer is written correctly, it should show up in the Start Menu. If they don't, simply make shortcuts.
jimnms said:Ok, I just gotta ask, why do you think it's bad computer practice to put things on other drives besides C:?
I've used a C: and D: partition/drive since I had a 386 with DOS. I keep most programs on D:, and every one of them is linked in the start menu.
jimnms said:In all my years I can only remember two programs that didn't work when I put them on a different drive. Back when I had that 386, I put all of my games on D:\Games. I can't remember the name of the game now, but it would only work if it was in the root directory of C:. Another was Falcon3 which wouldn't work if it was in a subdirectory (D:\Games\Falcon3), so I had to put it in D:\Falcon3..
djnes said:Because software that isn't written to allow for different paths may have trouble finding certain components. It's one of the fundamentals that's taught to Windows Application developers. I at one time used to think I'd be slick and install software to my second drive. I always encountered problems with different apps, and I decided from that point on, I would only use logic and common sense for my computer. C gets the OS, apps and games. D is reserved solely for storage. Therefore, rebuilding is much much easier.
