Ok so I have the chaintech nvidia3 Mobo wich is suppose to have onboard sound. Now I insert my speaker plug (the green one) into a green hole in the back of the comp. and I dont get any sound! How do I turn on onboard sound???
Did you make sure it's enabled in the BIOS?
Did you install the drivers for it?
Is it listed as being installed correctly in Device Manager?
Do the drivers let you specify which plug is the output?
