Just trying out stuff for fun. Decided to see what HDMI would do instead of DVI and I can only select 1920x1080. I've looked all over CCC and Vista and am stumped.
I know I've heard people running their PC over HDMI..............haven't I?
Did a little reading around and see threads from people with the Westinghouse having to hack EDID or drivers or something but that is only with nvidia cards. I have ATI.
When I run off of hdmi, 1920x1200 is not available as a resolution. Shouldn't it be available? Does my computer think I am hooked to a TV?
The computer will read the EDID from your monitor to get the available resolutions. Are you running it through any HDMI switchers or is it just a straight path from your PC to the monitor?
I know you're just trying it out, but as long as your TV/Monitor treats the 2 connections the system, which most do, HDMI isn't going to look any better than DVI. Probably not worth messing with.
