BanDeodorant
- Jul 3, 2007
Okay guys, I've hooked my parent's computer to a 32" samsung with a resolution of 1366x768, but I can't set it to that resolution in the Catalyst Control Center. Is there any way to make a custom resolution?
Also, I have the computer hooked up to a 17" lcd monitor (1280x1024), if that matters at all.
Another issue I'm having is that when the HDTV is on extended desktop, i can drag a movie that's playing fine, but once I maximize it, it goes back to the 17" monitor. So how can I make it so that when it maximizes, it stays on the screen where the window is at?
Does anyone have answers for me?
Thanks.
P.S. Any other suggestions about the best way to approach this lcd + hdtv setup would be great as well, thanks a lot.
Forgot to say, the computer is using an ATI HD 3200 integrated graphics.
