I plan to buy an Enermax Noisetaker 375W power supply : http://www.cluboc.net/reviews/power/enermax/eg375p-ve/
Now, I will not be using this with a motherboard. Instead, I will hook up a switch to the ON pin on the atx connector to turn it on manually and use it to power 12 HDD's and a dozen fans (can be seen in the disk storage system forums). This particular power supply has 2 12v rails, each supplying 13 and 14 amps. My question is, how do I go about 'using' both rails in my particular setup? Will I have to splice certain wires on the ATX connector to utilize the second 12v rail? I would hate to use a bunch of power splitters on one 12v rail while not using the second one.
Thanks for any help you guys can provide
