How do i flash my mobo?
GOD'SlittleSERVANT
i got a Micro Star KM266 and my bios is Phoenix Tech., version 6.00PG and my specs are in my sig. thanks
go to motherboard manufacturers website and download latest bios for your particular model and they should have a flash utility of somekind available for download as well
make a bootable floppy and put flash utility and bios on floppy as well
boot comp off of floppy and before hand either write down flash utilility name and bios name ..or type in "dir" (without the quotes) once you get to an A:\ prompt do show you directory of floppy to give you what you need to type in usually something like: flash uberbios.rom
If your not having system's problems, don't bother with flashing your bios.
ditto
Also, if you must, make sure you have a good power connection. If your computer looses power during the flash your motherboard is pooched :(.
And some boards you just have to push "F2" to get into the BIOS flashing program.
