How do I find my memory voltage settings
whoiskb
I have a Dell Dimension e510 and would like to buy some new ram for it. How do I find out the current voltage settings for the memory in the BIOS? Any insight would be helpful.
Thanks
Good Luck. Many Dell BIOS' are not accessible even fewer if any allow voltage adjustments.
Having said that you merely need to know what kind of ram your system has/uses [ddr2 for instance] and acquire that kind of ram if you want additional ram
thanks for the quick reply.
Here is what I am trying to do. I know my dell takes DDR2 800 and I want to upgrade my memory, but its a short term solution. Next month I will be building a new computer and the memory I buy now for the Dell, I want to use in the new computer. I am looking at DDR2 1066 memory and am worried about compatibility in my existing dell.
Will I be okay?
Thanks
It may just underclock the memory to DDR2 800. It shouldn't cause any fatal problems though. Why don't you just wait to buy it until you get the new computer, if your building in a month anyway, seems you could hold off.
Even if you did get the RAM working at full speed in the Dell, your not gonna see any major speed increase, i would just *(A) Buy it and save if for the new build (B) Wait and buy it with the rest of your components.
What size modules are you buying? 2x2gb? If so i'd make sure the board can handle 2gb per slot, ya never know lol.
Good luck with it bro!
Agreed just wait a month. ddr2 1066 should run at 800 but in your case what's the point
