I have a Intel G31-based motherboard. In the bios, I have setup the onboard sATA (SATA ports provided by the G31 chipset) to "Enhance". According to the manual, this mean the PATA port (there is 1 provided by the chipset) is disabled and SATA ports work in "SATA" mode.
I have using a ESATA bracket which are plugged into free SATA ports provided by the chipset. I plugged in my drive to this bracket. I plugged the data cable first and then the power cable. Well, my PC doesn't recognize the HDD. I plugged the power cable first but still no luck. I looked at device manager and I cannot see the ESATA drive.
This is on a newly installed Vista machine.
Any suggestions/recommendations?
thank you
thank you
