What do I need to accomplish this?
Switch A is connected to Switch B
Port 1 on Switch A will only talk to port 1 on switch B, and vice versa
All of the other ports on both switches function normally
The conntection between the 2 isolated ports is layer 2, no subnetting to keep them seperate, I need to be able to use any range of IPs between.
Basically there are 2 switches connected together via gigabit. I want to be able to have an isolated ethernet connection between the 2 closets without having to run a seperate line
how do I do this?
thanks
how do I do this?
thanks
