how do i do a fps test
How to do it with the game's inbuilt code... That is from the game console...
Don't feel too bad my brothers in law's computer scores a whooping 200 on 3DMark05.
XP 2100+
Geforce FX 5600 256MB
ShuttleLuv said:
that probably doesn't mean much to him.
Fraps is a program that you runs while you play your game and displays your FPS in the corner of the screen.
Linkage
I don't use it myself but alot of ppl around here do.
How could it not mean much to him? It allows any game to show the fps values. That is, you don't need to do the console specific command. And I, along with most probably, find fraps to be very accurate. Hardocp uses it as well. If you're looking for console specific commands, here are some:
Raven Shield - pull down console, type fps
Unreal Tournament 2004 - pull down console, type stat fps
Quake 3 - pull down console, type cg_drawfps 1 (works for other opengl games also)
I'd personally just use fraps. :cool:
If you mean benchmarks, then some good ones are Aquamark 3, 3dmark01-05, Quake 3, etc
