RegisteredToPost
- Sep 21, 2004
I have absolutely no idea which HSF to buy for an optie 170. I might overclock to whatever speed i can get without adjusting voltages....
How do you pick?
How do you pick?
RegisteredToPost said:Was the scythe designed to be fanless, so if you wish to mount a fan it'll require zip-ties?
It's a tossup between the ninja and the zalman. Should i just flip a coin? Which one is easier to install?
RegisteredToPost said:Has anyone ever had this cooler not fit in their case? I have an antec soho file server case, and am wondering if it'll fit... Reading reviews on newegg, looks like some people had problems with that. 150mm isn't that big.
quoi? and quoi?SpoogeMonkey said:I saw a few potential problems. It doesn't have the 3rd wire for rpm monitoring, so if ou want to use a fan controller....kinda out of luck. Also, one person said that it vibrated alot....if you don't get it mounted good and tight, I can see that being an issue.
eBayRegisteredToPost said:I chose newegg because i have yet to encounter problems dealing with them. They ship fast as well. Unfortunately their stock of opteron 170's ran short...
I also don't really know the best places for hardware purchases... Monarch had good prices on opterons but negatives circulate about how fast they are to ship...I probably have atleast 3 days before i can even order, so where is a good place to pluck cooling goods from?
15% tax for anything that i buy. add duties to get anything over to this side of the border from a US vendor. double the list price of anything that you look at states-side and you have a pretty good idea of what i have to pay.{NcsO}ReichstaG said:What's wrong with eBay? I often from those eBay stores and save money because I often don't have to pay any tax and tax here in California is high(like 8%)
DFI Daishi said:you don't need a RPM lead for a fan to work with a fan controller, depending on the style of fan controller you use. any rheobus or other dial-type controller works just fine with fans that don't don RPM readback.
wow. you know, the funny thing is, last time i checked, both panasonic, who used to make panaflo fans, and NMB who now makes panaflo fans, are different companies from sunon. it's the craziest thing, but fans made by different companies are not the same, and have different properties.SpoogeMonkey said:As far as vibration goes, I've used several 100+cmf 120x38 sunon fans(no panaflows) and those beats are heavy, and would make any lady happy Since the op would have to make his own retention clips/zip tie the fan to the hsf, if its not held tight, vibration will definately become a noise issue if nothing else.
