how do i choose a fan
wahoyaho
i bought a antec slk3000b which has a 120mm fan at the back already installed (antec tricool) and there's a slot for another 120mm on the front.
do i just pick any 120mm fan i see? or is there something i should be looking at like cfm/dba and do i need to compare it to the tricool fan the i/o rate?
is it ok if i buy different ones or should i try to match the fan at the front and bank
