How do find Max RAM speeds on core 2 duo?
keldegar
I have a P5B-E and my max vdimm is 2.1v
How can I find my max RAM speeds safely? My memory is corsair xms2 ddr2-675 5400C4PT. Redbeard says it is some kind of Micron IC, but not the same one in the 8500C4 dominators.
My computer is rock solid stable @ 3.2ghz, and DDR2-800, 4-4-4-12
I just recently tried 3.4ghz, DDR2-850, 4-4-4-12 and it fails orthos blend very quickly (but doesn't crash or anything). it also fails with 5-5-5-15 timings. It also passes small FFTs for about 15min (i stopped it since It wasnt stable on blend anyway).
I am now trying 3.3ghz, DDR2-826, 4-4-4-12, and I am passing orthos blend 1hr+ so far..
does this seem like I have hit a memory speed wall? my mobo can't put anymore volts into vdimm. or could it possibly be something else?
pretty basic OC stuff, keep cranking that fsb and lowering your cpu multiplier (to make sure its not your cpu thats maxxing). If it fails blend test, then you've hit a wall :(
ah ok lemme try dropping my cpu multi to 6.
one question, aside from vdimm what can I try to get my RAM to run at higher speeds?
so far it passed running at DDR2-826mhz @ 4-4-4-12 for 5 hours orthos blend.
you're running your ram over spec and with max voltage at loose timings (you could try 5-5-5 though), there's not much else you can do. perhaps one of those DDR boosters will help, but I don't have any experience with those.
Thanks for your advice. I guess I should be happy to get my RAM running that high. I still feel like this RAM and CPU have more in it, I shoulda got the p5b deluxe. I think 2.2v vdimm and my ram could hit 900mhz, seeing as its doing 826mhz at 4-4-4 with only 2.1v. Maybe when the cheaper quads come out ill get a new mobo. Thanks!
