How deep typically are 19" rackmountable equipment?
imzjustplayin
I'm looking for a rack, preferrably used and cheap, I've seen some older racks that are 25" deep but I was under the impression this is too shallow, right? How deep typically is modern rack mountable equipment nowadays? I'm looking for a 4 post rack not enclosed so depth including "cooling equipment" shouldn't be factored in.
did you mean deep instead of shallow? :confused:
Anyhow, most of the racks in our server room are 25" deep.
Huh? lol I meant deep, Deep and shallow can be used to express the same idea... 25" Deep, depth, whatever, however I wasn't sure 25" was deep enough.
I re-read my question and it no longer makes sense... but I can assure you, at the time I was confused, lol.
How much space behind the rack should I allocate for? (The distance is from the rack to the wall)
I was thinking along the lines of 3" but then I started to try and imagine what 3" would be and looking it over, 3" doesn't seem like enough space between a rack and the wall. I'm assuming I need enough space to be able to mount equipment behind the rear posts and I guess enough room to be able to access the equipment from the rear. My absolute limit from the wall to the edge of the rack (front) has got to be 40" which is still a lot.
Well, it just depends on how you decide to configure your rack, and what sort of door or other swinging access thing you end up having back there or on the side. If you mount switch or PDU on the back side, you'll need a few inches for cords to curve around, but as long as you have access from the side, you shouldn't need more than that.
I've dealt with situations before where the cabinet is butted right up against the wall. You have to get creative and make sure that you've planned things out to avoid pulling a bunch of servers to deal with that one plug you forgot :D
lol, is it really possible to maintain a server in a cabinet by servicing it via the side panels?
