How complex is SSD + OS instalation for a beginner?
I just bought a Win7 32bit disk, but I haven't installed it yet.
I was thinking about getting this: http://www.amazon.com/Intel-SATA-2-5-Inch-Solid-State-Drive/dp/B004UAK2A4/
I currently have this MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128012
I was wondering if all I have to do is to remove my current HDD from the SATA cable and instead hook up the end of the SATA cable to the SSD. Then place the Win7 disk in the DVD drive and install windows. Then put the old drive into another SATA connector.
Is there something important that I left out?
Is it worth it to buy this SSD to install Win7 on it?
Depends what you are doing with your machine. For light use, an SSD might not be the right call - they are very fast, but may not provide much real-world benefit depending on your use patterns (email, web, etc). Also, I would not recommend a 40GB drive, as it will be very limiting for space, further minimizing the benefits of the SSD. If you have a Z68 motherboard, you could use the 40GB for SSD caching, but it is rarther small for a primary drive.
I would just use it for the OS and maybe firefox, the secondary drive would house all the games and programs. i surf a lot with >100 tabs open andi let the pc sleep a lot and wake it up often. i also play demanding PC games sometime
I have a 120 GB vertex 3 right now, and I have hibernate off, and my windows installation takes roughly 50 GB of space after about a year of running. If you go with a 40, you are going to have to micro manage your space quite often. The other poster is correct too, if you had the Z68 you could use it as cache, but for a beginner, as you say that you are, I probably wouldn't delve into a 40 GB drive for the OS.
ok ill stick with the mechanical drives. too high of a price tag for marginal benefit. thx for the answers
