how can this be?
dannifood4less
i noticed today that i netted over 9K, this is higly impossible, the only person i have borged is my brother, and his computer is broken, not to mention he only was running the standard client. up untill now my highest points in one day was not quite 7500 so where did the 1500 extra come from? FAHspy looks normal, right now it says 7165ppd. its said that or close to it all day.
im just very curious to see where the extra points may have came from.. the point value jump is near what im getting per smp client WU, or possibly 3 GPU WU's ..
http://hardfolding.com/fh_stats/index.php?pz=102&id=748462&tnum=33
---ohh well, back to playing FarCry2.. :D
WUs that hadn't made it through an earlier update are a distinct possibility, although I don't personally have any weird jumps today. Generally speaking, WUs catching up that hadn't been submitted earlier are the likely suspect.
ill check my FahSpy logs, but i dont thing i have had any problems sending work since last week.
just checked and i can confirm i havent had an EUE or any errors besides:
[04:30:19] - Failed to delete work/wudata_09.sas
[04:30:19] - Failed to delete work/wudata_09.goe
and that was sometime yesterday.
edit...
just checked the 1am update and 1 WU turned in, not by me ive been monitoring it since 10pm,, and the point value is 429, which isnt what ive been getting for my WUs..
GPU-480/WU
SMP-1920WU
ohh well i guess i have a mystery borg somewhere. maybe my mom finally turned hers on,, how much does a standard windoze sys tray client net?
about 200 points.. if your lucky depending on what processor you have.. i think i avg 177 with 1 cpu core running sys tray client, amd BE-2350 @ 2.1ghz
What was your Point turn in for the last couple of days? If your average is equal to your normal PpD, then it is likely points showing up tardy. Mine will occassionally do that. This is especially true if the SMP Servers are lagging and my SMP clients are sandbagging :)
