RandysWay said:Or, heres another way.... I'm assuming you're using WMP:
Goto options and lower the vdieo acceleration down a notch or two, restart WMP, then hit Printscreen. Now it isnt black anymore.
Kaizer said:Ive been using Nvidias dvd player, it has that function as one of the F keys. It can also do sound capturing for those all so important Office Space quotes.
I believe you have my stapler.
jimnms said:There's an easier way if you are using WMP. Start WMP, go to options, Performance, click Advanced and uncheck "Use overlays." Then PRTSCRN will work.
