How can I send back partial WU results?
eblamo
Anyone know how to send back partially worked WUs? I don't want my work to go to waste but I won't be able to finish a WU on a machine
Someone correct me if I'm wrong, but I don't believe that you can do that. Not positive on that one though. I thought it only sent partial units when your core crashed.
If the wu screws up due to a failure it will send partial results. Other then that it must finish in order to send the results. The partial credit for a failure is a "gift" to the folder. Unfinished WU's are of no value as they are, unfinished.
If on the other hand you have another machine you can copy the whole set of files over to that machine and finish it there. If your going to run it as a second copy and run it at the same time then add -local to your command line.
