How Can I Remove These Dents
|Nexus|
How exactly do people remove dents from computer cases?
Case: Antec 1200
The 2 dents are on the right side panal (the one without a window), and it's made out of steel with black paint on it. I want a method that will not damage the paint, and one that's proven to work. Thanks.
There are a number of ways to "pull" a dent out. It might not work depending on the nature of the dent. Look for things like "dent puller" or "pops a dent"
depending on the size and location of the dent, you can use dry ice to pop dents out
Have you ever tried either of those on a steel computer case panel?
I have not done this, sorry.
The dry ice trick might be myth. A variation on that is canned air using CO2 propellant held upside down. There is also canned circuit coolant specifically design for this task. A variation of this heats the surface first. I've not done any of these myself and I don't know how it might affect the paint finish.
I ended up hammering them out, and as destructive as that sounds I'm actually happy with the jobs results.
