whisper
- Mar 16, 2003
I am running Win 7 64 bit and having issues with a process named "IAstorDataMgrSvc.exe". I know what this is and it was useful before I switched my SATA mode from AHCI to IDE (long story there, but it was necessary in order to avoid numerous system hangs and BSODs I was experiencing due to iaStor errors). For a little background on how I did this, see this article.
Now this process, IAstorDataMgrSvc.exe, still loads when I start Windows and I discovered it puts a near constant 25% load on at least 2/4 cpu cores at all times. It didn't do this when I was still running on AHCI but now it's doing it under IDE. This is annoying to say the least, and in order to shut it down I have to go into the task manager and then into the resource monitor (it does not show up in the task manager but does appear in resource monitor). Shutting it down seems to have no effect on my system.
I tried using msconfig to disable the "IAStorIcon" item under startup, but this did not prevent the process from loading on startup. Under the Services tab, I see the Intel(R) Rapid Storage Technology item and it is currently checked - I am wondering if it's safe to uncheck this and if that will prevent IAstorDataMgrSvc.exe from running? I assume the RST process is useless now that I am no longer using AHCI, but I wanted to ask before I do something hasty and screw up my system
Thanks
Thanks
