baballin328
- Sep 7, 2006
I have a AMD 3200+ winchester at 2.412GHZ (268x9) on a Gigabyte GA-k8NSC-939. I want to get it higher, but I don't know what else to do. I have the ram ratio thing at 2/1.33. My corsair value select is running at 3.0 cas, 3-3-3-8. HT multiplier is at 3x. if i try to overclock higher, my comp just restarts as it's loading windows. I thought the ram was overheating, so i put a fan over it, but that didn't change anything. How can i get it higher??
Thanks!
Thanks!
