I have a Netgear WNR2000 and my PC is connected wirelessly to it with a Linksys WMP600N at about 40 feet away. I want to know how I should go about on increasing my throughput speeds over wifi. I have tried allowing only N clients and have also look for the best channel in my area (which I think is 3). Whatever I do, my throughput on my PC is at about 7 megabits when I do a speedtest. The max speed I've been able to get on this PC in it's current location is about 1 megabyte/sec at the very most, usually 800-900kbps. When I go through a wired connection I can get 24 megabits over a speedtest and usually 2-2.4 megabytes/sec DL sustained. A far cry from what I currently am getting over wifi from 40 feet from my router. What do you recommend I do to increase the throughput? External antennas are out of the question for the router since it has internal ones. I have however looked at a cantenna. Would this be a wise choice and would it increase my wifi throughput speeds? If not, what do you guys recommend? Thanks for your help in advance. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
