I had a Linksys Wireless-G router for a long time and had very good luck with it. However, I ended up getting a couple of Wireless-N devices and wanted to get a different router. I bought the Linksys E3000. I got it home and set it up, and at first it worked. Then it would all of a sudden drop everything connected to it. I would restart the router, and in short order it would drop all connections again. This completely baffled me for awhile, until I actually touched the bottom of the router, and it was quite hot. I had it laying flat on a a table, so I could never understand why it was getting so hot. Anyway...I stood it up on it's side and it worked for awhile. Then it would randomly drop various things connected to it. The last straw was when I was listening to internet on the Apple TV, while viewing the internet on my PC and it started dropping the connection every five minutes. Anyway, I have now hooked my Wireless-G Linksys back up and it is working great.
The questions I have are these...is Wireless-N even needed? I live in a small place, so I don't need it to reach a long distance, and I don't transfer a tremendous amount of date wirelessly, so that doesn't really matter. Should I even try to fix this router? I looked on the Linksys page and I am running the newest firmware. I appreciate any help you guys can give me, and you need anymore information, let me know.
