I have a number of questions, as I like my OS to be just as I want, and had a fair bit of success getting XP to do as I wished. Vista, on the other hand, is a big stupid mess.
1: How can I remove or hide the folders?
Those "contacts" and "favorites" type folders keep reappearing when I delete them. Right click>hide doesn't work either. I hate them and want them to die.
2: How do I change the system folders?
These blue ones won't allow me to alter the icon path as the cream ones do. Similar issue for other system icons. Fair enough, but then why does it create both blue/cream folders? I found some registry cleaner/system tweaking program for XP, and wondered if there was anything similar for Vista that might allow me to dick with these icons.
Is there any way to edit the start menu's document links?
I've done as much as I can with the right click> properties business, but there're no options for things like "Recent items". is there a way of further adjusting what appears, and possibly even moving them around?
Thanks in advance.
Thanks in advance.
