How can I convert usb to serial
AZBOOSTIN
I am trying to take a small usb device the smaller camera style plug, and plug it into a 25 pin serial port... what can I do to get this to work.... Is this possible
as in, the old double row serial ports? not a P2/2 port?
I've never heard of such a converter. I'm fairly certain that none exist.
What are you trying to do?
You could chop off the usb plug on the cable though and solder it yourself to a female serial end.
and some of those drivers are junk... a co-worker has had nothing but problems with his USB-->serial device... and we make the friggin coverters!
You want to connect a USB device to a PC serial port because it doesn't have USB? I don't think any such adapter exists. You could buy a USB PCI card for the computer for less than $10.
I'm confused. It sounds like you want to connect a USB device to a serial port. This is not possible without some complicated, expensive electronics. The adapter linked above is for the opposite scenario - connecting a serial device to a USB port. Could you elaborate a bit on what you are trying to do?
