whisper
- Mar 16, 2003
Here's my question below... very short and sweet:
I'm using WinXP Pro with sp2, and am looking for a straightforward way to control EXACTLY which apps, processes, etc. load at startup. Is there a utility or something I can use to do this? I'm trying to troubleshoot a porblem, and have some suspects in mind.
Thanks
If you're interested and want more info, keep reading...
My problem: Some apps and services won't load. The system just hangs for a sec and then nothing happens (as if I had never tried to load it). Affected programs include Avast! antivirus, Ulead DVD MovieFactory, Windows Help and Support (from the start menu), System Information (from accessories-->system tools) and others. There doesn't seem to be much of a connection among the things that don't load, and I'm not sure why many of my other programs DO yet some do NOT. One thing is in common: if I boot into safe mode, everything can load again as normal.
Possible problems: I've installed a lot of stuff recently so it could be any number of things. I have a gut feeling it may have something to do with a new printer I installed (HP Photosmart 7450). It installed a whole bunch of things that run at startup (in task manager there are six hp processes now running). Short of just trying to uninstall the entire package, I would first like to see what happens if I just disable them from running at startup. So that's why I'm asking about this in the first place. Thanks again for reading.
Thanks
