How can i check my cpu temp
Ron1jed said:
I got a intel 915 board. 3.4 p4 with ht. ANy suggustions
If you have an actual INTEL motherboard, then you should get Intel Desktop Utilities. You can
monitor system temperatures, voltages, fan speeds, and hard drive health; view detailed system information; back up valuable files to CD, DVD, or a hard drive; and test your system hardware for common errors.
hmm most mobo should come with a tool for you to check your temps, umm you can also check you temp in the bios or if you have a Intel mobo you can download that tool that gn0me has mentioned.
ya its a actualy intel board. i'll download that program and check it out
