I've been trying to figure out if there is a way disable or restrict a user's ability to open the "View Wireless Networks" in WinXP and/or prevent him from switching networks, without much success. Any suggestions would be greatly appreciated, even an authoritative "Can't be done" would be helpful. WinXP pro, normal (non-admin) users.
If possible is their a way to completely remove the Wifi status icon from the task bar? I mean completely remove not just the option in the properties that says don't display when im connected because the icon still comes back when you are not connected which gives the back door for letting the user connect to open wifi.
Any thoughts? Registry/Policy changes?
This is posted twice, was not sure which topic.
It's a security issue but also at the OS level.
