hstuehmeyer2000
- Apr 2, 2006
Arcygenical said:Pretty simple. See that chair? Clean off your table, and put the chair ON the table. Now take your Res/pump and put it on the chair so it's clearly above the rest of the components. Go wild. Leave it a day, flick it on and off... it's up to you. What are the specs on that pump? Have you considered inline pumping?
EDIT ** Or... just hold the pump/res above your head for a couple minutes... it's your call**
