How 'bout a 16 channel KVM?!
jmroberts70
== UPDATE===========
Just completed the buildup of the first 8 umbilical cables (just the 6' cables). The remaining 10' cables are waiting on some power cable I ordered to get them built. Check it out below...
Started setting up the 10' cables!!!
I managed to land this little jewel from eBay a few months ago and have been slowly building the cable umbilicals and collecting power distribution and router hardware but here's some of the shots:
Here's a shot of the front of the KVM switch along with a 16-port hub I started with.
The back...
Here's the box of cables that came with it. I've been working on adding power and ethernet to each run.
Here's how it sits presently sits. I replaced the 16-port hub with a 24-port. I'm working on getting a 24-port switch for the final configuration though.
The KVM at work!! I've only completed 4 umbilical cables anyways! You can still see my old Belkin 4-port KVM at the top right. It served me well but I just needed more channels.
I found that the box 'cables came with both 6-foot and 10-foot versions so I've got to fab some extra long AC power cables now. I also will need one additional power distribution panel for the final configuration. Wish me luck!!
jmroberts70 said:
$40 baby!!
You suck!
j/k :p
Nice find man.
I need to get a bigger KVM, I currently have a 2 port, and I really need a 4 port. Sad thing is that I'm going to pay more for a 4 port than you did for that. :D
JSClark said:
Hm, I could have tons of fun with a 16-port KVM, and farming some extra computer parts ;) :D
Well here's what I'm planning on controlling with it:
Passive backplane systems with dual redundant PSU's
All P-III SBC's. Just add RAM and HDD --although I'm not really planning on adding any HDD's at this point.
I'd tell you all what I paid for this stuff but if you didn't like what I paid for the KVM, you'll all be REAL pissed when I tell you I paid about $200 for all these rack mount systems (along with a bunch of other networking stuff).
OMFG! That is a LOT of folding power right there! :eek:
Holy shit...
If you ever get those all up and running, let me know what it adds to your electric bill! :p
Had some time over the holidays and my lower back problems to get the first set of umbilical cables built up. Lots of soldering and splicing!!
Originally these guys included a mono audio connection, serial, and AT keyboard connection that I didn't need --but also I wanted to run power and ethernet along these guys too. So I removed the serial and mono line, snaked ethernet and power, spliced out the AT keyboard connection, and spliced each power cable to the exact length I needed.
So I start with a cable like this...
And end up with this...
Shifted things around in the rack to route the ethernet cables more directly...
Routing through the shelf holes I drilled in the workshop...
All nice and clean runs now. All I have left are 8 more of these to build!!
and what might you use these for?
and where did you get them?
Well I currently run 3 servers from that station, I also troubleshoot a lot of PC's from time to time and like having spare connections available. It's also nice when you order a good half-dozen workstations for a client and want to set them all up at the same time! I'm gearing up for a much larger setup (see earlier posts for pics of all the machines) that I will use for a business I'm starting. I got most all the gear off eBay over the years. The 24-port switch was a gift from a network admin. that upgraded his office to gigabit.
Another update...
Here's the KVM switch in use setting up a triple set of Dells while running my fileserver...
Getting started on the 10' cables...
You can see all the old spot ties I've got to remove along with all the extra cable connections 'n stuff.
Now all the unnecessary cables cut out and ready for splicing...
Now I only have to wait for some power cables to come in the mail so I can get to soldering! Oh boy...
