Well here is the situation. I am putting in a wifi network for a company and the goal is to beam the signal accross their parking lot to another building. The buildings are lester shed type (metal walled sheds). I have come down to the idea to use a outdoor wifi router on one side and then hopefully just a standard client on the other side (usb wifi).
I like the look of the engenius routers. They are decently priced, outdoor rated, and powerful. http://www.newegg.com/Product/Produ...50002037&Manufactory=2037&bop=And&Order=PRICE
My question is, do I need the 16dbi flatpanel version (EOC-3220+) or the 9dbi flat panel version (EOC-3220). The two are the same except for the larger gain patch panel in the one version.
The run is probably about 400 - 500ft and the thing will be mounted outside the one building but have to penetrate the remote building.
