How big is Win2k?
win 2k minimum requirement is 650 MB, but the final installation will be smaller, some of it is used as swap space. This is windows ONLY clean install. I dont remember offhand how big my initial win2k installs were, and now I'm loaded with apps,updates etc...
The recommended minimum drive size to accomodate swap and a few apps is 2GB but you can get away with 1 GB, it's a bit cramped though.
