So I finally decided to make the switch from Apple to PC, simply because as an engineer i will need to be using CAD software daily (mainly SolidWorks and Pro-E), and i really want to build something and learn new things.
Ill be building my own computer, and wanted some advice from all your long-time pc'ers.
Here are the components im thinking of getting.. .:
NTEL BOX CORE I7 960 3.20GHZ 4C HT 8M 4.8GT/S S13
ASUS S.1366 INT X58/ICH10R ATX3PCIE X16,6D.DDR3-13
KINGSTONVALUERAM-MEMORY-12GB:3X4GB-DI
1TB BARRACUDA 7200.12 SATA
32MB HD ASUS ENGTX470/2DI/1280MD5,GF GTX470,PCI-E 2.0,1280
LITEON 24X24 DVDRW SATA BLACKRETAIL, DUAL MICROSOFT OEM USB 2000 KB &
MOUSE OPTICAL
ANTEC SONATA III TAC MID 500W POWER SUPPLY
3 YRS PARTS & LABOR WARRANTY
2 x ASUS ML248H 24" WIDE LED, 2MS 1920X1080 10,000,000
$2575 + tx
Firstly, ive been looking at ANTEC's enclosures, and quite honestly prefer the NSK 4480B (http://www.antec.com/Believe_it/product.php?id=MzU=) but the Sonata III 500 has 500W power supple, and the NSK only has 380W. I'm not familiar with power supply minimum requirements, but Ive been told not to go under 400W. Is that true?
Now my main question is about the monitor(s). Im currently using on a 17inch macbook pro, so the jump up to 24inches seems big... but even bigger if i go for dual monitors.
I decided that ill forsure invest in the dual monitors, but now its a question of size. Are two 24'' monitors simply too big ? I know most of you have more, but I dont game, and would only be using it for design work.
Also, my desk is 160cm x 80cm, so im scared ill be sitting too close to such big monitors.
Finally, any one have the ASUS ML248H? im looking for affordable monitors that look sexy. (coming from a design background (and as an apple user), sleek and stylish are important to me! )
thanks in advanced !
MOUSE OPTICAL
$2575 + tx
