Right now, my HTPC consists of:
C2D E8400 | Freezer 7 Pro | Mild Overclock to 3.33GHz
Gigabyte P35-DS3R with F11 BIOS
4x Corsair XMS2 DDR2-800 1GB
Zotac 9600GT 512MB Amp Edition
Hauppage PVR-150MCE
Seagate 320GB, WD Caviar 1.0TB
Pioneer DVR-A12XLB
SilverStone LC20B-M
2x 8mm Artic Cooling Fan
Vista Home Premium SP1 (RTM)
I had no problem before, running 2x Seagate 320GB with Silverstone ST405 (400W). Yesterday, I upgrade one of my Seagate 320GB to WD Caviar 1.0TB Green Power (4 Platters), and then the problem came up, the WD Caviar didn't work well. Then, I borrowed Silverstone ST50F (500W), and tried it up, but still had no luck. It's even worse, I couldn't start windows. After doing trial, I came up with conclusion, that the power supply didn't have enough power. Right now I run the system with 2 power supplies, ST405 powers the Caviar 1.0TB, and ST50F powers the rest of the system. It's working perfectyly as before.
I'm feeling rather wierd, that WD Caviar 1.0TB Green Power, needs so much power. So, do you have any suggestion for the power supply. How much power is enough? Or do you think my system has another problem, not due to power supply?
Regards,
LimLim
Hauppage PVR-150MCE
Pioneer DVR-A12XLB
SilverStone LC20B-M
Regards,
LimLim
