Talonz said:If you fail an overclock, there is almost a 0 percent chance of hardware damage. The only way hardware can be damaged is if you overvolt components too much. When your system crashes from an overclock, just reset the CMOS jumper. Quick and painless.
titanium said:Well I've reset my jumper a few times pulled the CMOS battery put it back in. Now everything will power on but wont get post. My power switch wont even work properly it acts like a reset button.... sigh whats going on?
mobiux said:The only think i have heard of an OC screwing up is data on a HD.
But that was in the old days where you didn't have locked pci bus speeds.
Shouldn't hurt anything these days.
