Celsius temps are basically standard in oc world. Are these temps idle or load. Are occlocked or not? What type cooling do you have? All these factor are need to determine if you have good temps. It's relative, kind of.
What's your room temp? Nobody ever posts that...it's important. If your room is 40 degrees Farenheit, and you have stock, your temps are gonna be better than a guy with watercooling and his room is 78 degrees.
