How are these temps?
evanscnce
Iam running an E6850 overclocked to 3.8ghz.
it idles at 10c and load at 20c whille playing Crysis.
These temps looking good?
Laing DDC
2 papst fans
stealth rediator
TDX block
MCres
all on 3/8 tubing.
Now ijust gotta get a GPU block and a p35 block mwahaha
so you sold off the gigabyte 680i then? damn...i really need to get rid of that NB block! which revision of the pump do you have? which stealth? 120.3/2/1?
Yea, my gigabyte is outta my rig.
its a revision 1
120.2
I was suprised at the temps to be honest :)
Oh and iwill follow who i want, unless there is a court order against it :(
Those temps is impossible. With what software did you check the temps ?
Ding ding ding ding ding, aaaand we have a winner with "Too good to be true!"
OP: Without any mention of doing anything exotic, your temperatures are below typical ambient room temperatures. With a straight up watercooling system it is physically impossible to get below ambient. You could be confused and are telling us deltas, you could be using some sort of chiller setup, you could live in an igloo in the north pole. However until you elaborate some more I am calling shens.
10C is possible ... Hell, it's 3C outside right now in central NH. But wait. My computer is in my house. :rolleyes:
"My watar c00lar is so gud it brakes the l0z of fizix!"
Ive used my mobo bios, PC Probe and speedfan and everest
Your not getting the point.... What are the ambient temps in your room or are you pumping in cooled air from the outsite. Like stated many times in this thread, it is impossible to have lower CPU temps than outside temps. Hell it's hard to acheive 10c over ambient.
I have a room in the basement that is usially in the 60s, then i have my windows open right near the PC.
