System:
- Core i7 920 D0
- Noctua NH-U12P (2 fans that came with it)
- Silverstone Raven RV03
BIOS:
- 196x19
- LLC enabled
- HT enabled
- CPU: 1.187V
- QPI: 1.2V
- DRAM: 1.64V
- everything else stock voltage
I think they are a bit high for 1.18V. What do you think? Did I make a mistake assembling or do I need a better HSF? Considering the case and HSF quality I just feel that they should be way lower, like high 50s instead of 60s.
- Core i7 920 D0
BIOS:
- 196x19
- LLC enabled
- HT enabled
- CPU: 1.187V
- QPI: 1.2V
- DRAM: 1.64V
