At idle, the cores are anywhere from 30-34 degrees celsius and at load, they instantly jump up to the 50-53 degrees celsius range.
Ambient is around 23-25 degrees. I reseated the HSF this morning using the proper TIM application technique (small pea amount in the middle). After about a minute, they're 53-58 (1 core is at 58 degrees celsius and seems to be the one that is the hottest :\) There is one fan on the Noctua as the my case - the Antec 300 - has a fan right on top of the HSF and one right next to it - both pulling out.
