Hi All,
I'm assembling a file server and was going to use my Antec SP-500 I had sitting around but it only has 2 rails and it doesn't look like its going to cut it for 12 drives. The 650 has 3 rails (19A max each) with 12 drives (3A max draw each) I could do 3:3:3:3 for the rails to split them up evenly but it raises the question, how are the rails divided up? The back of the 650 has 5 connectors on it and '3' rails, so which connectors should I use? I'd rather do 4:4:4 drives so that on those 3 lines there are only hard drives (no fans or optical drives) to keep noise down but will that overload the rail?
Thanks,
Sam
Thanks,
Sam
