how are my oc temps
joethemole
2500m @ 2.525 ghz 1.725vcore 2.8vdimm
with ALX-800 3000rpm fan
currently idling at 40c (on a fairly cool day), and yesterday when i ran prime, it averaged 46c max load after 9 hours, although it peaked at 49.
what temps shouldn't i be going over? 55 or 60?
From what most people say, it's best to keep your temps below 60c, but the lower you can get the better.
My work rig is a 1700@2.2Ghz running at 65+ all day long 24/7. Your temps are fins bro.
my athlon-xp does 2.5 ghtz at 1.7v and has full load temp of 110 F at highest... slk-800=alx-800 so...
(2400 rpm 80mm enermax fan here)
WOW 65c?? i dont suggest to go over 50c... i gained 10c with 100mhz using auto overclock so went back with manual overclock, got 200mhz overclock with stock voltage and 10c cooler then the 100mhz oc
