I decided to splash out on the Ballistix BL2KIT12864Z503 (2 x 1Gb), and ATM I'm seeing how high it will go before I start on the FX (I'm following the [H] A64 OC'ing guide for n00bs ).
I just finished my first runs, using MemTest to test for initial stability. I cranked my CPU multi down to 10, set HTT at 4x and locked the PCI at 33 & PCI-express at 100. I left the memclock at 400, dropped to 1t command rate, but left the latencies at stock 3-4-4-8 for now.
I just ran 2 passes of MemTest without errors at 255 (@ 2.8v) which looks OK for a start - I tried for 260 (@ 2.9v) but MemTest threw up a lot of red .
I'm still a bit new to this whole A64 OC'ing thing - is that an OK result? I was hoping to get a bit higher, but in a brilliant move I went for the Asus mobo rather than the DFI. Any tips on how I can squeeze a bit more out of my ram? I rigged up a temporary RAM fan but that didn't seem to do a whole lot.
Thanks in advance!
[k]
Thanks in advance!
[k]
